Repeater Mode Channel Selection for 2.4GHZ and 5GHZ Networks
Anthony Smith
Hi Everyone,
I'm using a Asus RT-AC66R
I have a quick question regarding repeater mode:
After I've set up the two repeating networks:
SSID: test2.4g
SSID: test5.0g
When I try clicking the "2.4ghz" at the top of the page, the page keeps refreshing between Advanced_Wireless_Content.asp and apply.cgi. When clicking "test5.0g" the page shows the advanced wireless settings, but are never actually saved after I've pressed apply.
I wanted to change the channel modes of the repeated networks to a static channel but the settings keep getting reversed for the 5ghz network settings, and the page is inaccessible for the 2.4ghz because of the looped call of the .asp and .cgi.
Could anyone provide me with some guidance on this?
Much appreciated.
Thank you so much!
-Anthony
Hi Everyone,
SSID: test2.4g
SSID: test5.0g
Much appreciated.
Thank you so much!
-Anthony
hi
being a "repeater" its repeats exactly what you are connecting to , so if the main transmission is on ch 6 then the repeater will also have to be on ch 6 , i think you would also use the same ssid names for the same reason
