Dijkstra88
Hi everyone,
At the moment I have an AX-88U router and an AC-88U in AP mode via Imesh. The AC-88U is wired in the attic via UTP from the AX-88U downstairs, so the laptop connects via WiFi. I have a fiber optic connection of 1Gbit up and down. For my work I spend at least 8 hours a day behind a computer screen and meetings via team. Minimum 9 per day. My work laptop has an Intel AX-201 WiFi adapter, so it can handle WiFi 6 protocol. The AX-88U is located downstairs in the living room. My work laptop is in the attic, as me and my girlfriend both work from home. The work laptop is therefore connected via WiFi and therefore does not use the WiFi 6 protocol.
My girlfriend's work laptop also has the AX-201 build into her laptop and is paired with the AX-88U. We change places every other day.
In addition, my game pc is also in the attic and is wired connected via the AC-88U. Because of this I get the full 1Gbit connection. (including downloading via newsgr.) Via Wifi this is only half (500mbit up and down max. As a telephone, I and my girlfriend use an iPhone 12 Pro Max that can also handle WiFi 6 protocol.
My question, is it wise to replace the AC-88U with the AX-82U in the attic? The AX-82U does support the Wifi 6 and has slightly faster arm CPU. Not sure if the WiFi speed will also improve while on the attic as it supports WiFi 6. I plan to also run Rmerlin software on AX-82U (adblock etc). The AX-88U already has Rmerlin.
Wifi 6E is around the door, but my experience is that, just like with Wifi 6 as an early adapter, you get many early adaptor problems. I also had this with the AX-88U at the beginning. Wifi 6E will also become cheaper later, as the latest Asus router costs more than EUR500.00. One year would pass at least before Wifi 6E becomes affordable.
Please provide your input.
Thanks in advance,
KR,
Thanks in advance,
KR,
