Replacing a QNAP TS-410; Hardware help
jstad
I am replacing my old QNAP TS-410 and would like to go with a DIY solution so that I am not stuck with another NAS with a slow outdated hardware.
Here is what I use my NAS for:
  • Sickbeard
  • CouchPotato
  • NZBget
  • Video Streaming to a handful Boxee and Roku set top boxes
  • Coordinating files between computers (rsync)
  • Music Audio Samples (thousands of samples for music production)
I am really trying to avoid overbuilding here. Currently I am running on all 4 bays with RAID5. However I would like this build to handle more than 4 drives so I can handle a drive failure a bit easier.
Questions after researching:
  • Is an Atom processor going to be able to handle this sort of CPU load from Sickbeard, CP, and NZBget?
  • Should I stick with RAID5 or should I migrate to some sort of RAIDZ configuration?
  • I have two Core i5 processors sitting around unused. One of which is the i5-2400S, would this be ok for power consumption or is it overkill to the point you'd recommend buying something different?
Though to get all those features plus the NAS features of user accounts, access control, automated backups, Time backups, DLNA, FTP, etc., etc, in a DIY kit.
I couldn't tell you what software might have all these, and an easy/simple UI.
Atom: nah. E350 would be a good choice. But first, find the software bundle. I don't think you can; I tried.
I actually don't think I will have an issue losing most of those NAS features as I don't use many of them now with my QNAP.
