Replacing DNSMasq DNS with Unbound
Denna
When replacing DNSMasq DNS with Unbound, how do you disable DNSMasq from providing DNS support ?
swetoast,
Thanks for the quick reply.
DNSMasq would still be used for DHCP.
entware-setup.sh was used to install Entware.
opkg was used to install unbound and dnscrypt-proxy.
I want to use unbound as a DNS cache that forwards to the DNSCrypt proxy.
Reading the link above, I can see how DNSCrypt is installed, but not how DNSCrypt takes over DNS. Perhaps in that example, DNSMasq is configured to forward to DNSCrypt.​
swetoast,
Are you referring to the "dnsmasq-dnscrypt-reconfig" script ?
The contents of this file is:
#!/bin/sh
append_on_demand () {
TARGET="$1"
shift
for LINE in "$@"; do
if [ -z "`grep -F \"$LINE\" $TARGET`" ]; then
echo "$LINE" >> $TARGET
fi
done
append_on_demand /etc/dnsmasq.conf "no-resolv" "server=127.0.0.1#65053"
Does this mean appending the following lines in the dnsmasq.conf file stops DNSMasq from acting as a DNS resolver ?
no-resolve
server=127.0.0.1#<port number Unbound is listening on>​
swetoast,
But the two lines disable DNSMasq from acting as a DNS resolver and point to another resolver, correct ?​
What is the difference between adding those two lines to dnsmasq.conf and dnsmasq.conf.add ?
swetoast,
Wrong.....those lines only tell dnsmasq not to use it's resolve files and use the server specified as it's upstream name server. It's still active as a DNS server. But you can then use that to point dnsmasq to your unbound server.
again john i never messed with unbound only dnscrypt so i got no freaking idea how that works i only used that installer to show how to pass arguments from dnsmasq the rest is up to denna
Absolutely agree....just correcting some info for Denna.
dnsmasq is so tightly integrated in the firmware, doing a firmware 'replace' is likely not to be easy. The only easy way I can think of is to specify the unbound server on the LAN page and disable the option to pass the router address so only the unbound server is passed to the clients for their DNS.
john9527,
I've been researching and trying for weeks to get Unbound and DNSCrypt working on Asuswrt Rmerlin to no avail.
As far as I've gotten is:
1) Installing Entware, Unbound and DNSCrypt on /dev/sda1 (external USB drive).
2) Adding the following lines in the /jffs/scripts/services-start file​
/tmp/mnt/Entware/entware/etc/init.d/S09dnscrypt-proxy start
/tmp/mnt/Entware/entware/etc/init.d/S61unbound start
3) Adding the following lines to the /jffs/configs/dnsmasq.conf.add file
port=0
dhcp-option=option:dns-server,192.168.1.1
4) Configuring the following in the /tmp/mnt/Entware/entware/etc/unbound.conf file
interface: 127.0.0.1
interface: 192.168.1.1
However, I don't see a way to determine if unbound is running. It does not show up when running top or ps.
/opt/etc/init.d/rc.unslung check
will tell you what is running in entware ... if they reply "dead" it sometimes means they won't start because of a bad config
tomsk,
Is this a path issue ?​
tomsk,
Ext4.​
Do you have a path to find in entware? find --version or "cd /opt/bin" you should be able to ls and see the find executable. The rc.unslung script calls find when it runs. You could do
/tmp/mnt/Entware/entware/etc/init.d/S09dnscrypt-proxy check
/tmp/mnt/Entware/entware/etc/init.d/S61unbound check
these should call the rc.func script which will tell you if these services are running
tomsk,
This is the contents of /tmp/mnt/Entware/entware/etc/init.d/rc.unslung.
#!/bin/sh
PATH=/opt/sbin:/opt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
# Start/stop all init scripts in /opt/etc/init.d including symlinks
# starting them in numerical order and
# stopping them in reverse numerical order
#logger "Started $0${*:+ $*}."
ACTION=$1
CALLER=$2
if [ $# -lt 1 ]; then
printf "Usage: $0 {start|stop|restart|reconfigure|check|kill}\n" >&2
exit 1​
fi
[ $ACTION = stop -o $ACTION = restart -o $ACTION = kill ] && ORDER="-r"
for i in $(/opt/bin/find /opt/etc/init.d/ -perm '-u+x' -name 'S*' | sort $ORDER ) ;
do
case "$i" in
S* | *.sh )
# Source shell script for speed.
trap "" INT QUIT TSTP EXIT
#set $1
#echo "trying $i" >> /tmp/rc.log
. $i $ACTION $CALLER
# No sh extension, so fork subprocess.
$i $ACTION $CALLER
esac​
done​
Does this have to modified to point to the mounted drive since this is where Entware is installed ?​
You shouldn't have to modify anything... the /opt symlink should take care of all that for you. There is something strange going on with your entware install though... can't quite see what as all the paths look good..... will have to think.... your rc.func has different permissions is one thing i notice
-rwxr-xr-x    1 tOmsK root          2786 Jan 13 19:25 rc.func
all the same for me
