Hi All,
RE: Could someone please explain the specific steps, and what code i need to add/change in asuswrt-merlin, in order to use iptables or another approach to increase my stock firewall 32 rule limit.
I am a newbie regarding the use of asuswrt-merlin. I have the stock asuswrt firmware (RT-AC68U) currently but i am considering using merlin to provide better firewall configuration. This is because i have hit the 32 inbound whitelist limit in the asuswrt > network services filter configs. I have my firewall set to whitelist things like (eg http, tcp, ssl, sftp, facetime, git, etc, etc ). I assume i am doing the right thing by adding them in as a whitelist.
my current whitelist rules in the network services filter look like the following:
Source IP - Port Range - Destination IP - Port Range - Protocol
blank - blank - blank - 80 - TCP
blank - blank - blank - 443 - TCP
blank - blank - blank - 2268:2297 - UDP (e.g. madeup)
etc
However i haven't yet been able to find a really clear and simple explanation of how to extend the existing firewall limit in these forums or elsewhere using asuswrt-merlin. I keep getting to explanations that are too complex or specific around certain issues for what i need.
From my understanding i can configure more rules if i install asuswrt-merlin and get my hands dirty with iptables config.
I have read this page https://github.com/RMerl/asuswrt-merlin/wiki/Iptables-tips What else i have tried is looking at the source code on github, and the help pages there and elsewhere, i have looked at using fwbuilder to make rules, i have tried to understand Iptables but not sure where they need to be configured etc.
What would be great if someone can explain:
Thanks in advance.
etc
- The steps to increase the 32 rule limit (using iptables or another approach) and a full example of what files i need to add/change in asuswrt-merlin
- If possible some suggestions of good tutorial resources to improve my firewall security using asuswrt-merlin.
Thanks in advance.
