netmik3
I have a couple issues with Merlin. I want you to get paid, I don't want you to disappear and I will be sad if I ever have to use a router without your firmware. I also don't want you expanding into other routers because quality will go down like Cyanogen did.
Anways, as much as I love Asus routers. What IF Merlin builds a Merlin Router?
It would work like this:
We build an HTPC that will turn into a router. Merlin turns into a USB live disk that supports very limited specs. Eg. for version 1, only one radio will the standard. Maybe this: http://www.newegg.com/Product/Product.aspx?Item=N82E16833320136
Performance would be epic when ran in ram and a real cpu. I can actually use vpn on the router without limiting my 30 mbps to 3 mbps.
However, I dont know if those radios are limited at all when ran in infrastructure mode.
I would totally pay Merlin $97 for lifetime updates.
