Reset DHCP Client List Names?
Therion87
Is there a way to reset the DHCP client list names to the given defaults?
I added custom ones and would like to reset them.
Or is a factory reset needed?
Thanks,
Do an "nvram show | grep some_name" to find which nvram setting contain that some_name, then "nvram unset" those variables.
Awesome thanks.
Worked perfectly. For anyone interested.
"nvram show | grep some_name" (a custom name you named something) returned "custom_clientlist" as the variable
"nvram unset custom_clientlist"
"nvram commit"
Clears all custom entries.
You would have to manually modify both the nvram content and the clientlist stored on the JFFS partition.
