Tech9
Part of the Furniture
Looks like a friend of mine got hit by some firmware update anomalies, but I can't get there in person to see what's going on. The system is RT-AC68U router with radios turned off and 2x EAP225 access points with auto assigned by DHCP IP. The access points are wired directly to the router and have own power supplies, no PoE switch. The question is if I reset the router remotely will the WAN connection be up during the initial Setup Wizard screens? The access points are up and running, but if I lose WAN-LAN there is a lot of explaining to do over the phone. What I have is AnyDesk connection to local PC. The ISP needs default Automatic IP only. Thank you!
The router is running stock Asuswrt, current release 386_51665.
