resolv DNS on the router - hosts file or some similar ?
Speedy1205
Hi Guys,
probably it easy question for you but I don't understand 100 percent where to put this.
I use the ownloud script with a domain domain.com. So when I access the owncloud from internet (wan) its working fine. But when I use it from LAN / WLAN I would like to use instead the routers IP 192.168.102.1 that not all the traffics are routed through the 3G modem.
I would do a Entry in /etc/hosts (on the router)
192.168.102.1 domain.com
But client still resolving to the public IP. Any Ideas ? The config is just out of the box with no changes.
sorry for spamming... my mistake. I was on VPN that's why it didn't work as I wanted.
now its fine without any entry :-)
