resolvconf: command not found
dony71
Trying to run wireguard script wg-quick which using resolvconf command
Get error /opt/bin/wg-quick: line 31: resolvconf: command not found
Which entware package need to be installed for this resolvconf command?
I suggest you follow the guide on this page to setup your wireguard....
I have RT-AC68U which mentioned in this forum not stable for wireguard
However I found website link below and I'm trying now but get stuck with this unsupported resolvconf command
Often BusyBox has stripped down versions of software. If you have entware installed, you can use
Opkg list
To see if there are any full versions available for resolvconf. Pipe the output to grep to help your search
(On a tiny keyboard, so I can't type this I want it).
I believe the following is from a back-level version of wg-quick....
set_dns() {
    [[ ${#DNS[@]} -gt 0 ]] || return 0
    # TODO: this is a horrible way of doing it. Has OpenBSD no resolvconf?
    cmd cp /etc/resolv.conf "/etc/resolv.conf.wg-quick-backup.$INTERFACE"
    cmd printf 'nameserver %s\n' "${DNS[@]}" > /etc/resolv.conf
unset_dns() {
    [[ -f "/etc/resolv.conf.wg-quick-backup.$INTERFACE" ]] || return 0
    cmd mv "/etc/resolv.conf.wg-quick-backup.$INTERFACE" /etc/resolv.conf
so if the Wireguard DNS directive is configured (you can try commenting it out) then the contents of '/etc/resolv.conf' is overwritten after the backup is created.
ASUSWRT-Merlin RT-AC68U 384.19_0 Fri Aug 14 19:17:44 UTC 2020
admin@RT-AC68U-C068:/tmp/home/root# opkg list | grep resolvconf
admin@RT-AC68U-C068:/tmp/home/root# opkg list | grep resolvectl
Opkg list
set_dns() {
unset_dns() {
Thanks for this script modification
However now the script stuck at
sysctl: command not found
I check opkg also doesn't have sysctl
Any suggestion how to change the script, not to use sysctl command?
