macster2075
Can I restore saved settings and jffs from previous version over to latest?
Thanks Dave...so if all the devices set with custom names and custom pictures, all that will be deleted and will have to be done again at every update?JFFS should be ok. Settings are not necessarily compatible because they can change between releases (e.g. new nvram variables, changes to length of nvram variables, change in content of nvram variables).
No, on an upgrade your settings will persist unless explicitly mentioned in the release notes (rare).Thanks Dave...so if all the devices set with custom names and custom pictures, all that will be deleted and will have to be done again at every update?
Yes, that is what I do. I do not uninstall or unmount or reset anything for a firmware upgrade. I do backup with a shell script files and nvram settings that I customize as I change them at best or at firmware upgrade time at worst.ok.. I'm just used to Tomato where it's recommended to always flash new firmware updates and clear nvram (factory reset). So you're saying, unless specifically mentioned in the firmware notes, I can just flash the update without having to manually set any settings or jffs afterwards?
There’s this for example:Thank you... I have been searching, but I can't seem to find it.. Is there a link to a page that shows the difference between the stock Asus Firmware vs Merlin?
like what features does one have that the other doesn't?
Thanks...I did try both the forum and search engine...I guess my search abilities are not that great
Welcome To SNBForums
