Restricting Windows 10 system to internal LAN with no Internet access
baddog
Hello.
Hopefully this can be done via firmware for my ASUS 1900P. If there is an easier method, or I have overlooked something, my apologies.
I am setting up an Intel NUC with Windows 10 (or Windows 10 Pro). After setting the system up I would like to disable all internet access for this system and only have it seen/accessible by other computers/devices on my local network.
Thus no "phoning home" for updates, etc...
I am using it as a music server, so once setup, I only need it to be available to other devices on my home network.
Thanks for any tips.
First thing i think of is to give it a static IP and leave gateway blanc
Verstuurd vanaf mijn A0001 met Tapatalk
Hello.
Network Map-> Client Status
Click the Win10 device icon, then in the popup window set 'Block Internet Access=ON' (remember to hit Apply!) and there should now be an 'Internet Globe' icon containing an overlayed red No-Entry icon next to the Win10 device icon.
or
AiProtection->Parental Controls->Time Scheduling
NOTE: The blocking uses the MAC address.
Thank you for the replies, will give this a go tomorrow when the memory for my NUC arrives.
Barr
