Revert Enable Access Restrictions
Josh Schneider
In my main router, I "accidentally" chose to enable access restrictions (Remote Access Config) to only one AP (I have 3 routers, the main and 2 APs). Now I can't access my main router's UI, which previously was reachable at 192.168.1.1 (with HTTPS on 8443). I also cannot SSH to this router now. Is there any way I can revert this mistake without completely resetting my main router? Thanks
Unplug the AP, and set your computer to use that IP.
Thanks. I bit the bullet and reset the router anyway. I had backed up the config recently, so it was pretty painless. OTOH, now I lost my previously configured AIMesh node, and I can't seem to reconfigure it as easily as I did once before.
I think I'd just forgotten how to get to the point where I could configure one of my other routers as an AIMesh node. Finally found it and am trying to set that all back up now.
