Risk level remotely connecting to router webui over http?
Axxel6307
Once in awhile away from home i need to open my asus webui app to connect to my router to turn router off remotely when i don't want my wifi running.
I'm in and out in just a few seconds. But it's done over http. Can my routers webui/admin password be seen during this brief connection and give someone a backdoor to my network?
...open my asus webui app to connect to my router to turn it off remotely.
Turn what off? Remote access? The router (there's no option to do that)?
Yes. But the much bigger problem is that Asus' HTTP web server is easily hackable and if it's normally open to the WAN it's just a matter of time (whether you're away from home or not)...
No, i mean shut my router off remotely using the webui.
So if its too risky leaving wan access enabled whether over https or http, is there a workaround way to connect to my router remotely?
I'm still not sure what you mean by "shut my router off". Do you mean physically power off the router? - There's no option for that. Or do you mean "disable the remote access features"?
Yes, use the OpenVPN server on the router and connect to that.
I'm sorry you are right. I meant reboot my router. I just said shutoff for simplicity since It's another can of worms why I need to reboot it remotely lol.
Anyway, thanks for the info bud.
The vast majority of home routers have very poorly written web servers, which are constantly the target of attacks. Don't expose your router's webui to the Internet, you are highly likely to have it compromised. Asus for instance fixes new web-related issues every few months, and Netgear recently recommended to their users not to expose their router's WAN to the Internet as a protection against the VPNFilter malware.
Use a VPN tunnel.
I suggest you reflash, reinitialise (factory default) if you have been leaving your router open to WAN via the asus app for some time.
Don’t use Asus app at all and NEVER open Wan access or ssh. Use OpenVPN server access via openvpn connect (iOS/android).
Good luck if you choose to leave it open.
Why is OpenVPN safer than SSH via keys only (i.e., no password)?
The openvpn code was recently audited. I don't think dropbear code ever was.
The increased security lies in the underlying code, not in the authentication mechanism itself.
Thanks.
Maybe I should indeed disable SSH over WAN and use it over OpenVPN instead.
I'll have to thank @Xentrk for popping this thread up...
Dropbear, while not having gone thru the openvpn audit, is fairly secure - use certs, and it's very secure...
Link is broken... please post again.
The member you quoted does not visit SNB Forums anymore and you replied to a thread >6 years old.
If you need OpenVPN access back to your home network just set OpenVPN server on your router, export the *.ovpn configuration file and import it on the client device you'll be using to access your network. You may need to install OpenVPN Connect application on this device, available for multiple platforms. If you have Dynamic WAN IP address you have to use DDNS service. Use search for more details, the matter was discussed multiple times.
Enable SSH from the lan, then connect to the router using OpenVPN. You can then connect vis SSH.
That sounds very convoluted.
The normal practice is generating a certificate on the client machine and produce a client SSL cert to install on the server and configure the SSH client to use certificate authorization.
even though this post was dusty, it needed a correct answer.
By using openvpn we avoid exposing the ssh server to the Web. Which method is more secure?
I'll stick with what I know, thank you.
SSH is neither more or less secure than vpn and with both programs, its normal to use SSL authentication instead of username/password on the internet side.
SSH does not use SSL authentication.
Its the standard way ssh is handled over the web.
Look up ssh ssl auth on google:
https://www.google.com/search?q=ssh+ssl+auth
The only quirk with store bought consumer routers, they normally have a cheap version of SSH called Bear Drop SSH and you have to use their tools to make a SSL or convert a standard SSL to their format. Most business class routers use OpenSSH for SSH and OpenVPN for VPN services.
Sorry, you are wrong. Look at your own google search results. (e.g. https://www.securew2.com/blog/how-does-ssh-certificate-authentication-work)
We are not talking about SSH tunnelled through a SSL/TLS connection or vice versa (which I think is what you're referring to) but a native SSH connection using public/private key authentication (e.g. RSA, ECDSA, etc). FYI Asus routers use dropbear (not "Bear Drop") which is a full implementation of the SSHv2 protocol.
