Release ROG Rapture GT-AX11000 v3.0.0.4.386.46065 (2022/01/11)
TBolley
ASUS GT-AX11000 Firmware version 3.0.0.4.386.46065
Security
- Fixed string format stacks vulnerability
- Fixed cross-site-scripting vulnerability
- Fixed informational vulnerability.
Thanks to Howard McGreehan.
-Fixed SQL injection vulnerability
-Fixed json file traversal vulnerability
-Fixed plc/port file traversal vulnerability
-Fixed stack overflow vulnerability
Thanks to HP of Cyber Kunlun Lab
-Fixed authenticated stored XSS vulnerability
Thanks to Luke Walker – SmartDCC
-Fixed LPD denial of service vulnerability
-Fixed cfgserver heap overflow vulnerability
-Fixed cfgserver denial of service vulnerability
Thanks to TianHe from BeFun Cyber Security Lab.
Added more ISP profile
Digi 1 - TM
Digi 2 - TIME
Digi 3 - Digi
Digi 4 - CTS
Digi 5 - ALLO
Digi 6 - SACOFA
Maxis - CTS
Maxis - SACOFA
Maxis - TNB/ALLO
Fixed AiMesh guest network issues.
Fixed DDNS issues where the WAN IP is IPv6
Fixed UI bugs in Administration --> feedback.
Fixed time zone error.
Improved the connection stability.
Please unzip the firmware file first then check the MD5 code.
MD5:5126c6f077a017013aff1c0a07727f94
working, super fine here
Asus is not supporting this router any more..... no updates for problems all other routers get fixes on the new firmwares , was thinking of upgrading to the new Axe rapture 16000 but think its going to be the same crappy support.
That is an unfair assumption. The AX86U got its last upgrade on the same date and I know Merlin has code Asus sent him for the 386.7 firmware.
I'm also in the same boat so I understand your frustration. But Merlin's FW has new binaries for this router so I expect a final release of a new official FW to happen soon. Just be a bit more patient.
Meanwhile switched to Merlin 386.7 on both Main and node, seems to be working fine (honestly more stable and faster connection)
So, new firmware = yes. :)
