Hello Community,
I am running Merlin 380.58 on a 68U. I am using PIA VPN on the router with policy based routing and got that setup to use client1,3,5 all pointing to different PIA servers. My goal is to create a few scripts that will allow me to rotate a given VPN client among the three PIA servers on a weekly basis using a few crude scripts and cron.
Here are my planned scripts:
vpn1tovpn3.sh:
#!/bin/sh
nvram unset vpn_client1_clientlist
nvram set vpn_client3_clientlist=<FranklinsiPhone>10.0.10.22>0.0.0.0>VPN
nvram commit
vpn3tovpn5.sh:
#!/bin/sh
nvram unset vpn_client3_clientlist
nvram set vpn_client5_clientlist=<FranklinsiPhone>10.0.10.22>0.0.0.0>VPN
nvram commit
vpn5tovpn1.sh:
#!/bin/sh
nvram unset vpn_client5_clientlist
nvram set vpn_client1_clientlist=<FranklinsiPhone>10.0.10.22>0.0.0.0>VPN
nvram commit
However, my testing of the nvram set command in the script does not appear to be working. I get the following error:
#nvram set vpn_client5_clientlist=<iPhone>10.0.10.22>0.0.0.0>VPN
-sh: can't open iPhone: no such file
If I assign the client source IP from the GUI and then run the nvram get command, I can see the following:
vpn_client5_clientlist=<iPhone>10.0.100.22>0.0.0.0>VPN
It appears I am providing the parameters correctly in the nvram set so not sure what could be causing this error. From the GUI, it appears that the field in question is the description field which would get populated when you select the source IP or you can type in whatever you want there.
If I run the nvram command using a different name like 'test' I get the same error. If I run the command like this (leaving description blank), it does not error out but I don't get the results I expected:
nvram set vpn_client5_clientlist=<>10.0.10.22>0.0.0.0>VPN
or
nvram set vpn_client5_clientlist=<10.0.10.22>0.0.0.0>VPN
It does not fail but seems to set the value as a blank:
#nvram get vpn_client5_clientlist
Any ideas what I may be doing wrong or if this is even possible? Thanks in advance.
vpn1tovpn3.sh:
#!/bin/sh
nvram commit
vpn3tovpn5.sh:
#!/bin/sh
nvram commit
vpn5tovpn1.sh:
#!/bin/sh
nvram commit
or
