Route only specific ports and hosts via VPN. All other traffic via WAN. (Asuswrt-Merlin)
kevinkey619
I'm currently using portmap.io so that I can have a static IP address over Starlink and access the RTSP streams of my IP cameras. So, I have it set up as a VPN in Asuswrt-Merlin. I'd like to route only traffic on port 554 via the VPN and the rest of the traffic via the WAN (bypassing the VPN). The reason for this is that if I route all the traffic on the camera via the VPN, it breaks the ability for the camera to synch with the time server and other functions.
I found out about https://github.com/RMerl/asuswrt-merlin.ng/wiki/Policy-based-Port-routing-(manual-method) , but I'm not sure how to make it work.
Here's my current /jffs/scripts/nat-start
#!/bin/sh
sleep 10  # During the boot process nat-start may run multiple times so this is required
iptables -t nat -I PREROUTING -i tun11 -p tcp --dport 554 -j DNAT --to-destination 10.0.1.118
exit 0
And in the GUI:
I just want Port 554 routed via the VPN, however.
Is that possible?
