Hi everyone, I'm hoping someone here might be able to help me understand some messages I'm seeing in my routers logs.
I'm running Asus-wrt and have been having a few internet issues recently so I turned on the logging in System Administration.
Question 1:
I see a lot of messages about connections being dropped (I'm not sure if this is a normal thing or not, but there seems to be a dropped connection every couple of seconds), is this normal? Here are a couple of snippets from the log, it's from a mix of source IPs and there are a mix of UDP and TCP connections being dropped:
Question 2:
The messages I'm a little more worried about are these ones, I believe the source 10.xxxx address means it is within my network but none of my internal IPs start like that, so I don't really know what these are. Should I be creating some sort of rule on my router to drop connections coming to port 68?
If anyone can help or point me to places to find out more, it would be greatly appreciated.
Question 1:
Mar 6 10:44:29 kernel: DROP IN=eth0 OUT= MAC=** SRC=45.93.201.131 DST=** LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=7481 PROTO=TCP SPT=40593 DPT=33914 SEQ=3675199252 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Mar 6 10:45:20 kernel: DROP IN=eth0 OUT= MAC=** SRC=195.54.161.151 DST=** LEN=40 TOS=0x00 PREC=0x20 TTL=244 ID=61218 PROTO=TCP SPT=41041 DPT=43422 SEQ=2451425515 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Mar 6 10:45:22 kernel: DROP IN=eth0 OUT= MAC=** SRC=94.232.46.25 DST=** LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=29784 PROTO=TCP SPT=48753 DPT=3402 SEQ=1567946565 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Mar 6 10:45:25 kernel: DROP IN=eth0 OUT= MAC=** SRC=89.248.165.166 DST=** LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=49833 PROTO=TCP SPT=46518 DPT=619 SEQ=3956362901 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Mar 6 10:47:35 kernel: DROP IN=eth0 OUT= MAC=** SRC=139.99.6.195 DST=** LEN=53 TOS=0x00 PREC=0x00 TTL=239 ID=15601 PROTO=UDP SPT=30120 DPT=27015 LEN=33
Mar 6 10:47:37 kernel: DROP IN=eth0 OUT= MAC=** SRC=139.99.6.195 DST=** LEN=53 TOS=0x00 PREC=0x00 TTL=239 ID=20008 PROTO=UDP SPT=30120 DPT=27015 LEN=33
Mar 6 10:47:37 kernel: DROP IN=eth0 OUT= MAC=** SRC=139.99.6.195 DST=** LEN=53 TOS=0x00 PREC=0x00 TTL=239 ID=7747 PROTO=UDP SPT=30120 DPT=27015 LEN=33
Question 2:
Mar 6 10:27:01 kernel: ACCEPT IN=eth0 OUT= MAC=** SRC=10.53.35.97 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=255 ID=59695 PROTO=UDP SPT=67 DPT=68 LEN=308
Mar 6 10:27:06 kernel: ACCEPT IN=eth0 OUT= MAC=** SRC=10.53.35.97 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=255 ID=59707 PROTO=UDP SPT=67 DPT=68 LEN=308
Mar 6 10:27:08 kernel: ACCEPT IN=eth0 OUT= MAC=** SRC=10.53.35.97 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=255 ID=59720 PROTO=UDP SPT=67 DPT=68 LEN=308
Mar 6 10:27:09 kernel: ACCEPT IN=eth0 OUT= MAC=** SRC=10.53.35.97 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=255 ID=59726 PROTO=UDP SPT=67 DPT=68 LEN=308
