router compatible with XT8
kaball
hi
i have some xt 8 router and i want to add some compatible ones. can you please advise which one are compatible (old ones).
Welcome to the forums @kaball.
The default answer is that all AiMesh routers are compatible (assuming they are able to run the same/current version/level firmware as the main).
However, in my experience, the most stable AiMesh systems are with two identical models.
