Router for multiple Xboxes
bickle
I'm looking for a router that works well with multiple Xboxes. Seems like a simple request, but there are lots of posts from people having problems with it. Apparently to support multiple Xboxes, the router has to have a strong implementation of UPnP.
Thanks,
Some routers also let you configure UPnP. There is an article on this website probably about router testing in which the firmware was tested against a multitude of features. If the router has good firmware than it is likely to work with your situation.
