Router for Steam link
Drizty
Hi all, I purchased a steam link and am looking to purchase a router to make use of its wireless function.
I was originally looking at the ASUS 68U but after looking into it I thought i may be better off putting an extra put of cash to minimize latency. I am now looking at the Netgear R7800 or the ASUS AC3100.
Will forking out an extra $100-$150 make a noticeable difference? are there other suggestions?
Notes:
  • I currently live in student accommodation and have no control of the network they supply, my computer and steam link can connect but neither will recongise each other, so I am buying this router to setup in my room to stream to the lounge room (i will also be using it for when I move out).
  • The router will be setup in my room and which is approximately 10 meters from where the lounge room is and will have to pass 4 walls.
If you're concerned about latency, use the ethernet connection rather than Wireless...
Sounds like the dorm WiFi might have AP isolation enabled...
I dont think Ethernet is a viable option for me, simple due to the location and where the cable would have to run
General consensus on Steam Link is that WiFi, while supported, isn't the best user experience due to latency, overhead, and unpredictable data rates compared to the wire...
Thinking maybe homeplugs - mostly due to lower latency than WiFi, and with HomePlugs one does have a modicum of control over QoS across that link.
I havent even looked into these (to be honest i haven't even heard of them).
Excuse my naivety, but for these to work id still need direct access to the router? or will 2 devices communicate with each other simply being powered (i attempted to describe this below)
Computer ---(ethernet)--> Homeplug #1 --(wireless)--> Homeplug #2 ---(ethernet)-->Steamlink
Homeplugs run in layer 2 (MAC layer), so they're transparent to the upper layers, and present as an ethernet connection...
AV1000/1200/2000 is likely more than enough - the challenge is jumping across circuit breakers, which you likely have in your environment (since you're crossing 4 walls)...
Check the reviews on the main site for HomePlug AV - the Netgear units have a decent reputation...
https://www.smallnetbuilder.com/tags/homeplug-av2
This is a little above my comprehension of Networking, however it has given me a good start on a good alternative option. I will look into this today, thank you!
