Router IP address
ualdrivr
Anyone know if the router IP address can be changed and how? I like it to be something deferent than the default 192.168.1.1. My router is an Asus 68U with the .5656 FW. Cheers
Yes, just change it to what you want but in private IP address range. Like 192.168.x.x
From then on you access router using that IP address. If you reset the router it goes
back to factory default address. My back up router is set at 192.168.100.1
Thanks Tony, I changed it. I found the menu that this could be done, under LAN settings. All done.:D:cool:
