Last night I had maybe 3 occurrences where it seemed like my wifi dropped. The first occurrence I unplugged my ISP router (ATT fiber router, Wifi Disabled, Passthrough mode enabled directly to my AX88U), and my main router (AX88U) and mesh node (AX58U). I did this maybe 8pm because we were streaming a show and it cut out and said it was a connection issue. Later that night it cut out again, and when I looked at my phone I wasn't connected to wifi. It was either the router is crashing and rebooting, or wifi is cutting out.
So I hopped in the GUI to look at the syslog. I saved the syslog from last night, but the issue just happened again maybe 15 minutes ago, so I grabbed that syslog as well. I've attached them both.
Could anyone see if the router is crashing and help me figure out why? One thing I've always been concerned about with my AX88U is memory. I'm always at 95% utilization so maybe something is pushing it up to 100% and the router is crashing.
Here's the custom add-ons I'm using. Diversion is disabled since I switched to AdGuardHome.
Thanks all.
1 open Diversion v4.3.2 -> v4.3.3
2 open Skynet v7.4.3
7 open unbound Manager v3.22
j3 open scMerlin v2.4.0
j7 open YazDHCP v1.0.5
vn open vnStat v2.0.4
rt open RTRMON v1.54
ag open AdGuardHome v1.6.0
ep manage Entware packages
sw manage Swap file /mnt/sda5 2.0G
i show all available scripts or tools
u check for script updates
amtm options
e exit t theme r reset a about
Thanks all.
