Router model
Welcome to the forums @papajoe41.
No, it won't.
No, it won't.
Correct me if I am wrong, but I believe that the RT-AX88U and AX6000 can be the same thing. Several of ASUS' routers have two names:
  • RT-AX58U == AX3000 (based upon market or retailer)
  • RT-AX82U == AX5400
  • RT-AX86U == AX5700
  • RT-AX88U == AX6000
"AX6000" is not a router model, it's just a marketing speed rating. The full name would be something like RT-AX6000 or GT-AX6000.
Thanks for setting me straight. This is inconsistent with the AX3000 and RT-AX58U which are the same thing in different markets. I checked again, and it is indeed RT-AX3000 which is equivalent to RT-AX58U.
Thanks for the info. I am looking for a new router and really want to make sure that I can use the Asus-Merlin firmware. How about the ROG Rapture GT AX11000?
Thanks, Papajoe41
Viktor Jaep- The list that you sent me is not the latest on the site (see insert). On there is the 'GT AX11000'. Does that include the ROG Rapture GT AX11000?
Thanks, papajoe41
The same router. This is the only Asus GT-AX11000. Folks around are more happy with different model though - RT-AX86U.
Thanks, Papajoe41
I am running Merlin 386.4 with an one month old GT-AX11000 (A1.1) and it is stable. Mind you that 5GHz-1 could be a lot weaker than 5GHz-2 depends on your country's regulations. Unless you really need an extra 5GHz band, the RT-AX86U might be a better buy (and likely have better firmware support in the long run considered its popularity).
I have joined this Asus Forum so that I can get answers from long time users or professionals about what this all means. Asus has the standard Asus routers, the Asus Gaming routers and the Asus ROG Routers. Are there significant differences that would make one be able to use the Merlin firmware while another cannot? A cannot find an GT AX11000 on the regular routers only on the ROG Rapture. So, can the Merlin 386.4 for the GT AX11000 be used on the ROG Rapture GT AX11000 unit?
Thanks, Papajoe41
Read the replies above. They're the same router. At least, today. ;)
Thanks, again. So, the thing to look at it is the AX11000 . The rest of the name just gives the manufacturer a reason to charge more. LOL
Papajoe41
No, the full model's name is the 'thing to look at'.
Asus GT-AX11000.
Anything else and you're potentially doing the bait and switch, on yourself.
