Ran into an issue that I've spent a while trying to figure out. Not sure if this is a problem with asuswrt-merlin or just ASUS Routers.
Basic layout...
Main Network (192.168.1.0/24)
- with static route for 192.168.10.0/24 -> 192.168.1.10 (LAN port)
Sec Network (192.168.10.0/24)
- with static IP set to 192.168.1.10 (255.255.255.0)
- gateway set to 192.168.1.1
- dns set to 192.168.1.1
- NAT enabled for port forwarding - incoming port 22 - go to -> 192.168.10.5
- NAT enabled for port forwarding - incoming 1900, 32410, 32412, 32413, 32414 UDP
& 32469 TCP - go to -> 192.168.10.8
This setup works with pfSense (just pfSense VPN doesn't work with the two I use), was able to have any DLNA player on 192.168.1.0/24 (ie xbox one) see the DLNA server on my 192.168.10.0/24 network.
I set this all up on with using and extra ASUS RT-AC3200 router and everything works (22 forward & VPN), but I can't get any DLNA player on my 192.168.1.0/24 network to see my DLNA server on my 192.168.10.0/24 network.
Not sure why I'm having such a hard time with asus routers basically aliasing a 192.168.1.10 address to 192.168.10.8 address then and port forwarding.
When I went back and tested I could get to for example 192.168.1.10:1900 using pfSense.
I tried the same thing with asus router and it gets blocked. Even with port forwarding 1900 to 1900 and IP 192.168.10.8 configured.
Basic layout...
