I recently joined this forum and have read a number of the thorough reviews as well as the posts. However, I have not seen anyone specifically address what router would be best in the following situation: We have two home offices in our split-level home. In the basement, a desktop is connected to a Linksys 802.11b wireless router (BEFW11S4 v2) via a CAT-5 cable coming from a 3Com OfficeConnect 10/100 Network Interface Card (3CSOHO100B-TX). On the top floor (1 1/2 floors up), on the opposite side of the house, in a second office is a laptop connected via an external PCMCIA card. The distance from the router to the laptop is about 55-60 feet on a straight line. The laptop accesses the files on the desktop and also uses the desktop as a mail server. Finally, a second printer with wireless (802.11g) capability was recently purchased and will be used by the laptop, but only sporadically. Since I cannot justify the expense of a dual band router, I have been looking at single band n routers. However, I am having difficulty in determining what "n" router is best for usage at 60 feet. I am aware that when the wireless printer is printing, it will slow does the n connection, but I am willing to live with that since the printer will only be used occasionally. Belkin's N+ router appeared to be a good compromise now that its price has come down, but the performance of this router in locations E and F on your chart suggest that it doesn't perform well over long distances. Is this true? If so, what do you recommend? Finally, I intend to replace the current NIC on the desktop with a gigabit NIC, but don't know how to determine which card my desktop (Dell Dimension 8200 [bios A01], running XP Pro sp2) will support. Can you point me in the right direction? Thanks.
