Fergal Reilly
Hi All,
I've recently purchased an RT-AC5300 and flashed it with Merlin (Firmware shows as 384.6). I'd like to have my home network use a VPN for the increased privacy it affords. To that end, I've got a trial of NordVPN in order to figure out the settings, etc.
As an additional wrinkle, I work from home, and my Work laptop uses OpenVPN to connect directly to my work network (but not all traffic, only work related traffic). I'd like to be able to set up the routing so that general internet traffic goes via the VPN, but traffic on the work VPN bypasses the NordVPN connection on the router, and goes out through the internet (no point in double-vpning for no good reason).
I've tried to set up the policy-based routing on the VPN client (based on the details here: https://github.com/RMerl/asuswrt-merlin/wiki/Policy-based-routing), but it just seems to be crapping out. The work laptop in particular struggles to connect to anything on the internet - but it does seem to be happening (to some lesser extent) on my home PC. Pages seem unable to load (or load and then die). Speedtest.Net seems unable to even run the test, sometimes it just silently stops, other times it throws errors about the latency test failing, etc.
I'm a relative novice when it comes to routing, so not sure what I'm doing wrong. Could someone point me in the right direction? The routes I have are (work gateway IP obscured):
LAN 192.168.1.0/24 0.0.0.0 VPN
Router 192.168.1.1 0.0.0.0 WAN
VPN Traffic 192.168.1.0/24 [WorkVPN Default Gateway] WAN
VPN Configuration
https://pasteboard.co/HBI6Dx5.png
VPN Configuration
