hellbringer
I'm looking for a router that can replace my WRT54GS and if possible my Zyxel 2602 ADSL2+ router.
It must have:
- Gbit LAN
- VoIP
- WiFi (b/g/n: don't care)
- Less devices
(see attached network overview, GS116, server & PC's on the other side of the room)
I have a Zyxel router that has VoIP capability but no WiFi, only the firmware is absently *crap* (DNS server issues, settings that won't apply, etc) so I put it in bridge mode and my WRT54GS handles all the network routing, DHCP, DNS, etc.
The drawbacks of using the WRT54GS, is that it does not have VoIP and is only 100Mbit.
Since I want to be able to view HD content on my mediacenter & transfer large files from and to my fileserver I want it all on gigabit.
The options that I found:
- Replace the WRT54GS with a gigabit switch and use the Zyxel for DHCP & routing (unwanted because of the abolutly crappy firmware & no WiFi)
- Extra gigabit switch behind the Zyxel router and use the WRT54GS like an accesspoint (unwanted because of the abolutly crappy firmware and 3 devices to handle 4 functions! (ADSL modem, VoIP, WiFi))
- Billion BiPAC 7800N (Does not have VoIP so need a extra ATA so also quite costly)
- All other 'normal' routers with gigabit LAN & WiFi that i found don't have VoIP so I always need a extra ATA.
Is't there a router that has all these functions so I don't have a pile of network devices underneath my TV?
It must have:
- Gbit LAN
- VoIP
- Less devices
