Router with OpenVPN + Failover + Killswitch ?
swealpha
Hello!
Do you guys know a easy install router wired or wireless that support this:
1. OpenVPN that turns off connection if the OpenVPN provider goes offline.
2. Failover, backup OpenVPN provider. Example: if NordVPN is down, use ExpressVPN.
Thank you!
(I have searched for 3 days now, i could really pay someone for a solution.)
(This post have been edited)
I’ve done this with both pfSense and Untangle. Do a google search on “pfSense VPN Kill Switch.” That should point you in the right direction.
I forgot to write that i also need some type of failover.
I have a health disease so it would have been great if it is something that is more easy to install.
I have read untangle has this from stock, do you think it works any good?
Thank you!
Untangle can do what you want, and it can do it from the GUI, but I can't say the setup is real easy. It depends on how network savvy you are. You can definitely get the help you need over on the Untangle forums. I use Untangle and I am extremely happy with it. Some advanced stuff like what you need takes a little more configuration. Its not hard but there are steps to be taken.
