Routing between Ubuntu OpenVPN and MikroTik
Roman
My goal is to be able to connect to private LAN (192.168.1.0/24) via Ubuntu VPS.
For example I want this forwarding: http://{Ubuntu WAN IP}:443 --> http://{Private LAN IP}:443
Please take a look at attached screenshots.
As I understand the problem is in inability to communicate between two gateways 192.168.7.1 and 192.168.1.1.
- Ubuntu VPS knows the route to private LAN subnet (192.168.1.0/24) and MikroTik router knows route to OpenVPN network (192.168.7.0/24).
- Ubuntu can ping MicroTik OpenVPN interface (192.168.7.2) and any OpenVPN client (192.168.7.0/24) and communication like http://{Ubuntu WAN IP}:443 --> http://{any OpenVPN client IP}:443 works fine.
- MikroTik can ping Ubuntu’s OpenVPN interface (192.168.7.1).
- Private LAN’s hosts (192.168.1.0/24) can ping MicroTik OpenVPN interface (192.168.7.2).
But !!!
- Ubuntu can’t ping MicroTik private LAN’s interface (192.168.1.1).
- Private LAN’s hosts (192.168.1.0/24) can’t ping Ubuntu’s OpenVPN interface (192.168.7.1).
I would very happy if someone is able to explain what’s really going on? Why routing doesn’t work?
mikrotik only supports TCP openVPN and not UDP. But if you get past that, you'll need to NAT on mikrotik. I typically use a blanket rule that NATs VPN clients so that they can communicate with local stuff, because you have 2 local IPs, the client's local IP and the mikrotik's internal VPN gateway IP.
Under your PPP settings, add your clients to an address list, in your NAT, do the source NAT thing for your VPN address list with the out interface being the bridge.
