ResumeNothing
I had originally posted this on the VPN forum, thinking this was a VPN issue. Additional details are on that thread:
https://www.snbforums.com/threads/openconnect-client-on-asus-rt-ac68p-router-not-working.40633/
I've been trying to get OpenConnect running from the command line on an ASUS RT-AC68P router that I've flashed with Asuswrt-Merlin. Everything seems to work, except that my IP is still the one provided by my ISP, and I believe I've narrowed it down to a routing issue where Asuswrt-Merlin immediately overwrites the routes that OpenConnect tries to add.
Before running OpenConnect, my routes look like this:
Destination Gateway Genmask Flags Metric Ref Use Iface
xx.xx.xxx.x * 255.255.255.255 UH 0 0 0 eth0
192.168.1.0 * 255.255.255.0 U 0 0 0 br0
xx.xx.xxx.0 * 255.255.248.0 U 0 0 0 eth0
127.0.0.0 * 255.0.0.0 U 0 0 0 lo
default xx.xx.xxx.x.res 0.0.0.0 UG 0 0 0 eth0
Afterward, they look like this:
yy.yy.yyy.yyy xx.xx.xxx.x 255.255.255.255 UGH 0 0 0 eth0
zz.zz.0.0 * 255.255.0.0 U 0 0 0 tun0
default xx.xx.xxx.x 0.0.0.0 UG 0 0 0 eth0
xx.xx.xxx.x is the ISP provided IP, yy.yy.yyy.yyy is the IP I should have from VPN, and zz.zz.0.0 looks like it was derived from the X-CSTP-Address, which is the same IP mentioned in this line of the OpenConnect output:
Connected as zz.zz.zzz.zzz, using SSL + lzs
What makes me think this is a routing issue is that I can't get rid of the "default xx.xx.xxx.x" route. This command seems to work for about a second:
route del -net default gw xx.xx.xxx.x dev eth0
Sometimes if I run "route -n" fast enough, I can see that it's gone, but then next time I run it, it's back again. At the same time, I can see the following in the system log in the router interface:
Aug 13 19:00:28 WAN_Connection: ISP's DHCP did not function properly.
Aug 13 19:00:28 stop_nat_rules: apply the redirect_rules!
Aug 13 19:00:32 WAN_Connection: WAN was restored.
Aug 13 19:00:32 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
My thought was is that there might be some sort of setting that would prevent the rules from coming back in and restoring the routes. I tried moving the file mentioned in the logs somewhere else, but that didn't seem to help.
It also seems like I might be able to prevent the rules from running if I can get routes set up fast enough that the WAN connection doesn't think there's a problem with the ISP's DHCP. Unfortunately, I don't have a very good grasp on what rules I need to make this work, and they seem to get over written before I can run them or not run at all because some other rule is already there.
Does anyone know of a setting in in the Asuswrt-Merlin interface I could change that would prevent it from overwriting the routes, or have an idea of what routes I can set that might prevent the rules from running?
Thanks!
Thanks!
