ThelostIcon
Trying to route some devices on guest 1 thru vpn client, seems to work ok if i enable the acess intranet option, but obviously that defeats the purpose of trying to isolate guest 1 from lan. When i disable intranet acess, guest 1 drops the vpn tunnel. I tried adding 192.168.101.0/24 which is my guest 1 range to vpn director, but no dice. Is this a limitation or am i missing something. Tried yazfi already, it did the trick, but for some reason my ui keeps freezing every time i click between yazfi and guest tabs, even on a clean factory restore, so i had to unistall.
