Greetings,
I apologize if this has been asked and answered. I have an AC87U running the latest Merlin firmware which occupies 192.168.1.0/24, connected to this I have an Ubiquity Edge Router X I have been playing with and it has an IP of 192.168.1.55 which is used as a gateway to another subnet which houses all my IOT devices, 192.168.148.0/24. I have static routes entered to enable connections between the 1 and 148 subnets and that works fine.
The problem is I have an OpenVPN client connection active with selective routing and while I can route anything directly connected to the AC87U (192.168.1.0/24) over the VPN and that works fine, when I try to route all traffic from the IOT subnet nothing can connect to the internet. I would do this by adding an entry in the selective routing for the VPN client of 192.168.148.0/24. As soon as that entry is made the IOT subnet cannot connect to the internet at all.
I have tried routing just a single device on the IOT subnet, which does not work. I have also disabled all firewalls on the ERX for testing to make sure that wasn't an issue. I also see where the AC87U is adding the routes for all the devices through the VPN in the log so I am pretty sure it is getting the entry for 192.168.148.0/24.
I don't think it should make a difference but the ERX is also connected over a media bridge (to an AC66U), but that works perfectly fine with the subnets so I didn't think it was an issue. I am also using DNSCrypt if that would cause any issues at all, it works fine with the regular VPN.
Thanks for any help in advance.
Seth
Seth
