Hi all,
Here is my set-up:
GS
N.B. for those who would be wondering why this set-up rather than simply have an OpenVPN Server running on AX-86U, the answer is simple: the RT-AX56U is powered-on/off on demand with a home plug.
Here is my set-up:
- Main router is AX-86U with 192.168.1.1 ip
- Second router in cascade (behind AX-86U) is AX-56U getting 192.168.1.98 as WAN ip from AX-86U, and has 192.168.98.1 lan ip with one PC connected to its LAN port, getting 192.168.98.32 ip
- AX-56U has an OpenVPN Server running TUN, and is accessible from AX-86U thanks to port forward.
- AX-56U has firewall disabled
- so far so good ... everything works as expected
- Then, when I connect with my W11 laptop to OpenVPN Server from outside the LAN, I can access 192.168.98.32 PC without any issue but I cannot reach any 192.168.1.0/24 devices, which is I guess the normal behavior ; so my question is: what is it missing to be able to access any 192.168.1.0/24 devices when connected via that AX-56U OpenVPN Server ? (I guess something related to routing somewhere ...)
GS
