Routing rules for Dual WAN?
joebloogs
Is there a detailed guide for setting up dual WAN someone can point out for me?
I specifically want info on Load Balance Routing rules for Dual WAN explained..
When you create a new policy for such a connection, there is Source IP & Destination IP with WAN Unit selection..
I figured Source IP is the IP of the specific device i want to point to use either one of the two available WAN's
What should the Destination IP be tho? I have been using "All" until now...is this correct or should be using an IP?
