Searched and couldn't find any posting on the Asus RP-N53 Repeater but I'm hoping some kind folks can help me here..
I have a RP-N53 Repeater that I connect to the Asus RT-N66U. I am unable to get the N53 to connect to the N66U on the 5Ghz range, even when the N53 is placed 1m away from the N66U.
When I use the N53's QIS to detect networks, it is able to detect the SSID (eg Home) of the N66U at 2.4ghz, but not the 5ghz SSID (Home5G which is also broadcasting).
I am able to connect to the 5ghz Home5G directly so I know the N66U 5Ghz is working. But the repeater does not detect the Home5G SSID (It detects only Home).
In the Network Map of the N53, it shows Connected to Home (2.4Ghz). In Repeater Mode, it shows 2.4Ghz (Home_RPT), bandwidth 20/40Mhz, Channel 6, with IP and MAC addresses. For 5Ghz (Home_RPT5G) it shows 20/40Mhz, Channel 36 and IP/MAC addresses. On the N53 blue LED display it shows only a strong signal for 2.4Ghz and no LED lit up for 5Ghz. I do not see Home_RPT5G being broadcast when checked on any of my devices (via Wifi Analyzer and InSSIDer).
Under System Log - Wireless Log, it shows 5G with Mac address and Phy Mode: 11a/n Channel 36.
Using InSSIDer on the PC, only 5Ghz from N66U, 2.4Hgz from N66U, and 2.4ghz from N53 can be detected.
How can I get the N53 to recognise the broadcasting 5Ghz Home5G, and repeat the signal at 5Ghz as well? Any ideas?
