RT-AC2900: NoIP DDNS won't update
v1tt0
Hello everyone. First of all I would like to thank Merlin for this awesome work on the firmware.
I've been using the a RT-AC2900 with Merlinwrt for 2 months now, coming from a DD-WRT setup and I'm really satisfied with the performance.
There is only an issue with DDNS I would appreciate your help on resolving. I am using NoIP for DDNS service and the router will not update changes in the IP, apart from the moment I hit update on the settings. The WAN side of the router is behind a NAT so I use External IP check. Force update interval is set to 1 day, and WAN IP and hostname verification is ON every 60 minutes. Router is running 384.8_2
Am I missing something? Thanks in advance.
