just bought a RT-AC3100, updated to latest asus firmware. I have a 5tb WD portable drive attached to USB and smb share enabled, guest log in allowed. Share is working, I can read/write root folder from Windows or android client. But when I try to open a folder with about 100 folders inside it never finishes. In fact, browsing any folder takes way longer than it should, but the one folder with lartge # of folders inside never finishes. As I said, it's about 100 folders, not an insanely huge number.
When I try to log into the router admin page the UI is very sluggish, suggesting the operation is causing the router to hang. I tried both USB 3 and 2 port. Disabled dlna, itunes server, printer server. Rebooted of course. I verified that the drive is fine by connecting directly to PC and running chkdsk and browsing the problematic folder.
Any suggestion? thanks
