rt-ac3100 ttl flash hangs
cohomology
So I am trying to help a friend with his bricked rt-ac3100 and had no success no matter what. The router cannot be put into recovery so I hooked up TTL. I managed to flash asus-merlin 384.13 but then the console seems to be stuck. I waited about 10 minutes and rebooted the router but everything remained exactly the same as before the flash. I am attaching the console output and hopefully someone with more experience can help me out. Thanks.
Beagle Term. https://github.com/beagleterm/beagle-term
Device found on /dev/ttyUSB0 via Connection ID 1
Digital core power voltage set to 1.05V
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S3000020F
00001750
RDLYW0 00000004
RDENW0 00000042
RDQSW0
    0000000000111111111122222222223333333333444444444455555555556666
    0123456789012345678901234567890123456789012345678901234567890123
 00 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++--
 01 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
 02 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++
 03 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
 04 ------++++++++++++++++++++++++++X++++++++++++++++++++++++++-----
 05 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++--
 06 ---------+++++++++++++++++++++++++++X++++++++++++++++++++++++++-
 07 --------++++++++++++++++++++++++++X++++++++++++++++++++++++++---
 08 ------+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-
 09 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-
 10 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-
 11 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++---
 12 ---+++++++++++++++++++++++++++X+++++++++++++++++++++++++++------
 13 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
 14 ---+++++++++++++++++++++++++++X+++++++++++++++++++++++++++------
 15 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
PW0
 01 -----------++++++++++++++++++++++++++X++++++++++++++++++++++++++
 02 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++
 03 -----------++++++++++++++++++++++++++X++++++++++++++++++++++++++
 04 -------++++++++++++++++++++++++++X+++++++++++++++++++++++++-----
 06 ----------+++++++++++++++++++++++++++X+++++++++++++++++++++++++-
 08 -------++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-
 11 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---
 12 ----+++++++++++++++++++++++++++X++++++++++++++++++++++++++------
NW0
 00 -+++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++
 01 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++
 02 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++++
 03 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++
 04 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++
 05 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++
 06 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++
 07 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++++
 08 ++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++
 09 --+++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++++
 10 --+++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++++
 11 --+++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--
 12 ++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++++---
 13 ++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++++---
 14 ++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----
 15 +++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-----
WRDQW0
 00 ++++++++++++++++++++++++++X+++++++++++++++++++++++++---------++-
 01 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------+-
 02 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-+------
 03 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-+------
 04 +++++++++++++++++++++++++X+++++++++++++++++++++++++----------++-
 05 ++++++++++++++++++++++++++X++++++++++++++++++++++++++---------+-
 06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++---------++-
 07 +++++++++++++++++++++++++++X++++++++++++++++++++++++++--------+-
 08 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
 09 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
 10 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
 11 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
 12 +++++++++++++++++++++++++X++++++++++++++++++++++++-----------++-
 13 ++++++++++++++++++++++++X++++++++++++++++++++++++---------------
 14 ++++++++++++++++++++++++X+++++++++++++++++++++++--------------+-
 15 ++++++++++++++++++++++++X++++++++++++++++++++++++-------------+-
WRDMW0 00000026
WRDMW0 00000025
ADDR
 00 +++++++++++++++++++++++S+++++++X++++++++++++++++++++++++++++++++
Decompressing...done
CFE version 7.14.131.1608 (r589038) based on BBP 1.0.37 for BCM947XX (32bit,SP,)
Build Date: äº 11æ 17 16:37:23 CST 2015 (ham@xpdev)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1400,*800*
et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.1608 (r589038)
CPU type 0x0: 1400MHz
Tot mem: 524288 KBytes
CFE mem:    0x00F00000 - 0x017A7AE0 (9075424)
Data:       0x00F500A4 - 0x00F505E4 (1344)
BSS:        0x00F505F0 - 0x00FA5AE0 (349424)
Heap:       0x00FA5AE0 - 0x017A5AE0 (8388608)
Stack:      0x017A5AE0 - 0x017A7AE0 (8192)
Text:       0x00F00000 - 0x00F46540 (288064)
Device eth0:  hwaddr 70-4D-7B-E4-4D-78, ipaddr 192.168.1.1, mask 255.255.255.0
        gateway not set, nameserver not set
Null Rescue Flag.
boot the image...
go load
Loader:raw Filesys:tftp Dev:eth0 File:: Options:(null)
Loading: TFTP Server.
..tftp retry wait 0
Failed.
Could not load :: Interrupted
CFE> ^C
CFE> ^C
CFE> ^C
CFE> show
Incomplete command: "show"
Available "show" commands: clocks, devices
*** command status = -2
CFE> show clocks
Current clocks: 1400/800/250/125 Mhz.
*** command status = 0
CFE> show devices
Device Name          Description
uart0                NS16550 UART at 0x18000300
uart1                NS16550 UART at 0x18000400
nflash0              Zentel NAND flash size 131072KB
nflash0.boot         Zentel NAND flash offset 0 size 512KB
nflash0.nvram        Zentel NAND flash offset 80000 size 1536KB
nflash0.trx          Zentel NAND flash offset 200000 size 1KB
nflash0.os           Zentel NAND flash offset 20001C size 129024KB
nflash1.boot         Zentel NAND flash offset 0 size 512KB
nflash1.nvram        Zentel NAND flash offset 80000 size 1536KB
nflash1.trx          Zentel NAND flash offset 200000 size 63488KB
nflash1.brcmnand     Zentel NAND flash offset 4000000 size 65536KB
eth0                 Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller
CFE> flash
     flash [options] filename [flashdevice]
     Copies data from a source file name or device to a flash memory device.
     The source device can be a disk file (FAT filesystem), a remote file
     (TFTP) or a flash device.  The destination device may be a flash or eeprom.
     If the destination device is your boot flash (usually flash0), the flash
     command will restart the firmware after the flash update is complete
     -noerase     Don't erase flash before writing
     -norescue    Don't check anything
     -offset=*    Begin programming at this offset in the flash device
     -size=*      Size of source device when programming from flash to flash
     -noheader    Override header verification, flash binary without checking
     -ndump       dump nand flash
     -block=*     which block to dump
     -forceflash  Dangerous Command, Don't use if you don't know what you do
     -erase       Erase the partition, can set the  offset and length
     -cfe          write to flash and stay at cfe command mode
     -mem         Use memory as source instead of a device
CFE> nvram erase
CFE> flash -noheader : nflash1.trx
Reading ::
TFTP Server.
..tftp retry wait 0
- last blk -
Done. 37343232 bytes read
Download of 0x239d000 bytes completed
Write kernel and filesystem binary to FLASH
Programming...copysize=37343232, amtcopy=37343232
done. 37343232 bytes written
OK I got a little more information.
CFE> flash -noheader -cfe : flash1.trx
Reading ::
TFTP Server.
..tftp retry wait 0
- last blk -
*** command status = 51204096
So the flash did not complete succesfully since the status code is non zero.
keef AC3100 Router with AC3000 Mesh node ASUS AC Routers & Adapters (Wi-Fi 5) 8
