RT-AC3200 2.4Ghz Problem
thomaspleasance
Hi All
I am having problems with my AC3200 when my devices connect to 2.4HGz they are slow and the connection drops out. I have noticed that it is only running at 20MHz but I am unable to increase this without turning off smart connect any idea what could be causing it?
Firmware Version:3.0.0.4.378_7177
SSID: "ASUS"
RSSI: 0 dBm    SNR: 0 dB    noise: -90 dBm    Channel: 6
BSSID: 14:DD:A9:6F:6F:00    Capability: ESS ShortSlot
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
VHT Capable:
    Chanspec: 2.4GHz channel 6 20MHz (0x1006)
    Primary channel: 6
    HT Capabilities:
    Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ]
    VHT Capabilities:
    Supported VHT (tx) Rates:
        NSS: 1 MCS: 0-9
        NSS: 2 MCS: 0-9
        NSS: 3 MCS: 0-9
    Supported VHT (rx) Rates:
        NSS: 1 MCS: 0-9
        NSS: 2 MCS: 0-9
        NSS: 3 MCS: 0-9
Mode    : AP Only
Stations List
MAC               Associated Authorized    RSSI PSM SGI STBC Tx rate Rx rate Connect Time
XX:XX:XX:XX:XX:XX Yes        Yes         -66dBm No  Yes No     19.5M   72.2M 00:00:43
XX:XX:XX:XX:XX:XX Yes        Yes         -32dBm Yes Yes Yes    19.5M      1M 00:02:27
XX:XX:XX:XX:XX:XX Yes        Yes         -54dBm No  Yes Yes    19.5M   72.2M 00:03:31
XX:XX:XX:XX:XX:XX Yes        Yes         -56dBm No  Yes No     19.5M      1M 00:03:35
XX:XX:XX:XX:XX:XX Yes        Yes         -57dBm Yes Yes No       39M     24M 00:03:39
SSID: "ASUS"
RSSI: 0 dBm    SNR: 0 dB    noise: -89 dBm    Channel: 36/80
BSSID: 14:DD:A9:6F:6F:04    Capability: ESS
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
VHT Capable:
    Chanspec: 5GHz channel 42 80MHz (0xe02a)
    Primary channel: 36
    HT Capabilities:
    VHT Capabilities:
        NSS: 1 MCS: 0-9
        NSS: 2 MCS: 0-9
        NSS: 3 MCS: 0-9
        NSS: 1 MCS: 0-9
        NSS: 2 MCS: 0-9
        NSS: 3 MCS: 0-9
Mode    : AP Only
Stations List
XX:XX:XX:XX:XX:XX Yes        Yes         -70dBm No  Yes No      6.5M     24M 00:00:47
XX:XX:XX:XX:XX:XX Yes        Yes         -51dBm Yes No  No     19.5M     65M 00:03:33
XX:XX:XX:XX:XX:XX Yes        Yes         -50dBm No  Yes No    526.5M   1053M 00:03:37
SSID: "ASUS"
RSSI: 0 dBm    SNR: 0 dB    noise: -92 dBm    Channel: 100/80
BSSID: 14:DD:A9:6F:6F:08    Capability: ESS
VHT Capable:
    Chanspec: 5GHz channel 106 80MHz (0xe06a)
    Primary channel: 100
    HT Capabilities:
    VHT Capabilities:
        NSS: 1 MCS: 0-9
        NSS: 2 MCS: 0-9
        NSS: 3 MCS: 0-9
        NSS: 1 MCS: 0-9
        NSS: 2 MCS: 0-9
        NSS: 3 MCS: 0-9
Mode    : AP Only
Stations List
XX:XX:XX:XX:XX:XX                          0dBm No  Yes No                   00:00:00
XX:XX:XX:XX:XX:XX Yes        Yes         -76dBm Yes Yes No      234M     24M 00:02:23
My experience of RT-AC68U and RT-AC3200 is that the 2.4G AUTO channel setting will always choose 6.
Try finding a quieter channel and set it manually.
hope this helps
