robgbc
Hi All, Long term Merlin user here. It seems like there are several reports on the forum recently regarding wireless problems with 380.66x across multiple devices and I've been wrestling with mine all weekend.
Since upgrading to 380.66_2, wireless on my RT-AC3200 has been very unstable, basically unusable. I've reset the router via GUI and Power/WPA many times, re-flashed the firmware and set it up from scratch but to no avail.
After reboot wireless radios drop offline within minutes, tested with multiple devices and new SSID/PW to ensure any one device isn't knocking the radios offline.
When the router wireless starts malfunctioning it interferes with my Bluetooth mouse which develops so much lag that it becomes pretty much unusable until router is power-cycled.
Logging into GUI shows a half lit wireless icon with 2.4g and 5g radios reporting channel 0 or undefined, reboot temporarily restores radios.
I reverted back to 380.65_4 as previously it was stable, however the same wireless symptoms as described above are still occurring after firmware downgrade, factory reset, reboot, router setup. JFFS partition has been formatted.
I also tried installing latest Asus firmware via Firmware restoration utility however no change in radio stability.
It feels like the radios are corrupt as symptoms persist across multiple older firmware versions.
With radios disabled wired connections appear to be stable.
At this point I am at a loss as to what to do next but would appreciate any specific suggestions.
Thank you, Rob
Model RT-AC3200
Firmware Version 380.65_4
Firmware Build Wed Mar 29 04:41:19 UTC 2017 merlin@44495cc
Bootloader (CFE) 1.0.1.6
Driver version wl1: Jun 13 2016 17:17:21 version 7.10.274.33 (r527132) FWID 01-c00758b0
Thank you, Rob
Model RT-AC3200
