RT-AC3200 SmartShare not working properly
atlantistm
Hello,
I have a RT-AC 3200 which I updated to firmware version RT-AC3200_3.0.0.4_378_9459 with hardware reset.
Everything works fine but with this FW vers. I have problems with the Media Server through DLNA.
I connected an external HDD on USB 3.0 port but when i start a movie on my smart TV with SmartShare which is connected to
Wi-Fi 5Ghz-2, the movie stops after 15-20 mins and it disconnects.
The problem started from this vers.: 3.0.0.4.378.9135. Will the problem be solved in the future ?
Thanks.
File sharing not working properly even with usb 2.0. The movie stops after 15-20 mins and it disconnects.
Does nobody really have this problem ??
I've had unstable behavior on 3200 ever since the firmware hit the .9xxx range. (It was not perfectly stable prior, but it definitely got worse.)
