So for some reason I am unable to shut off QoS in the RT-AC3200 GUI. I click the slider to off but when I click APPLY button there is no action. Using Web Developer in Chrome I can see there is a javsacript error of some kind. Same thing in firefox so not browser or extension specific.
I just got 1GB internet and am only getting about 600MBps on the router but direct to cable modem I get the 1GBps. Posts online seem to say that disabling QOS might fix this and pump the speed up to full.
Is there any line command I can telnet/ssh in and use to just disable it manually? Have not done any tinkering inside routers before but am experienced linux admin. Not sure what the commands are on this router, variables, where things are, etc.
Any help much appreciated!
