RT-AC5300 Random WiFi Restart
NickBurns
RT-AC5300 380.69_2 upgraded January 28th from 380.69. Since this upgrade the following restart has occurred twice. LAN is unaffected however all WiFi is temporarily lost; all devices affected.
Was on 380.69 pretty much since it was released and it too occasionally had the 2.4Ghz channel drop completely while both 5Ghz channels were uninterrupted. The GUI would show a partial WiFi icon and show that it was channel 0 on the 2.4 Ghz band.
The Chromecast packet flood issue that came up in the last month may have been the cause of the above 2.4 Ghz channel drop. I still have that on the network but I disabled the option Google recommended as a workaround. For two weeks since disabling that option WiFi was stable -- however it may still be related.
There is one other thread where the below logs are dumped mid thread and no one replied to that query.
(yes, I've obfuscated my MAC below)
@RMerlin - any luck on obtaining GPL for recently released 384 for RT-AC5300? I see from ASUS' demo router running this release that the DHD driver is 1.363.2 but with a later (higher) r(release) build number.
What's puzzling however is 1.363.2 < 1.363.45.xxxxx so are they using a newer build or an older build in 384?
Jan 29 11:24:25 kernel: dhdpcie_checkdied: msgtrace address : 0x00000000
Jan 29 11:24:25 kernel: console address : 0x003FFCF0
Jan 29 11:24:25 kernel: Assrt not built in dongle
Jan 29 11:24:25 kernel: TRAP type 0x4 @ epc 0x27c408, cpsr 0xa80001d3, spsr 0xa80001f2, sp 0x2aacac, lp 0x33f7b, rpc 0x27c408
Jan 29 11:24:25 kernel: Trap offset 0x2aac54, r0 0x200968, r1 0x0, r2 0x2008d4, r3 0x0, r4 0x4, r5 0x0, r6 0x3be48c, r7 0x280001d2
Jan 29 11:24:27 kernel: dhd_detach(): thread:dhd_watchdog_thread:1a3 terminated OK
Jan 29 11:24:28 kernel: dhd_detach(): thread:dhd_watchdog_thread:19d terminated OK
Jan 29 11:24:28 kernel: dhd_detach(): thread:dhd_watchdog_thread:197 terminated OK
Jan 29 11:24:32 kernel: PCI_PROBE: bus 3, slot 0,vendor 14E4, device 4365(good PCI location)
Jan 29 11:24:32 kernel: dhd_attach(): thread:dhd_watchdog_thread:362a started
Jan 29 11:24:32 kernel: Dongle Host Driver, version 1.363.45.58013 (r651509)
Jan 29 11:24:32 kernel: Compiled in drivers/net/wireless/bcmdhd on Jun 15 2017 at 14:50:24
Jan 29 11:24:32 kernel: Register interface [eth1] MAC: 30:5a:3a:xx:xx:xx
Jan 29 11:24:32 kernel: PCI_PROBE: bus 4, slot 0,vendor 14E4, device 4365(good PCI location)
Jan 29 11:24:33 kernel: dhd_attach(): thread:dhd_watchdog_thread:3630 started
Jan 29 11:24:33 kernel: Dongle Host Driver, version 1.363.45.58013 (r651509)
Jan 29 11:24:33 kernel: Compiled in drivers/net/wireless/bcmdhd on Jun 15 2017 at 14:50:24
Jan 29 11:24:33 kernel: Register interface [eth2] MAC: 30:5a:3a:xx:xx:xx
Jan 29 11:24:33 kernel: PCI_PROBE: bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jan 29 11:24:33 kernel: dhd_attach(): thread:dhd_watchdog_thread:3638 started
Jan 29 11:24:34 kernel: Dongle Host Driver, version 1.363.45.58013 (r651509)
Jan 29 11:24:34 kernel: Compiled in drivers/net/wireless/bcmdhd on Jun 15 2017 at 14:50:24
Jan 29 11:24:34 kernel: Register interface [eth3] MAC: 30:5a:3a:xx:xx:xx
Jan 29 11:24:34 kernel: IGMP Query send failed
Jan 30 22:52:35 kernel: dhdpcie_checkdied: msgtrace address : 0x00000000
Jan 30 22:52:35 kernel: console address : 0x003FFCF0
Jan 30 22:52:35 kernel: Assrt not built in dongle
Jan 30 22:52:35 kernel: TRAP type 0x4 @ epc 0x27c408, cpsr 0x280001d3, spsr 0x280001f2, sp 0x2aacac, lp 0x33f7b, rpc 0x27c408
Jan 30 22:52:35 kernel: Trap offset 0x2aac54, r0 0x200968, r1 0x6, r2 0x20093c, r3 0x3f46f8, r4 0x4, r5 0x0, r6 0x3bd600, r7 0x280001d2
Jan 30 22:52:37 kernel: dhd_detach(): thread:dhd_watchdog_thread:1a3 terminated OK
Jan 30 22:52:37 kernel: dhd_detach(): thread:dhd_watchdog_thread:19d terminated OK
Jan 30 22:52:37 kernel: dhd_detach(): thread:dhd_watchdog_thread:197 terminated OK
Jan 30 22:52:41 kernel: PCI_PROBE: bus 3, slot 0,vendor 14E4, device 4365(good PCI location)
Jan 30 22:52:41 kernel: dhd_attach(): thread:dhd_watchdog_thread:24f1 started
Jan 30 22:52:42 kernel: Dongle Host Driver, version 1.363.45.58013 (r651509)
Jan 30 22:52:42 kernel: Compiled in drivers/net/wireless/bcmdhd on Jun 15 2017 at 14:50:24
Jan 30 22:52:42 kernel: Register interface [eth1] MAC: 30:5a:3a:xx:xx:xx
Jan 30 22:52:42 kernel: PCI_PROBE: bus 4, slot 0,vendor 14E4, device 4365(good PCI location)
Jan 30 22:52:42 kernel: dhd_attach(): thread:dhd_watchdog_thread:24f7 started
Jan 30 22:52:42 kernel: Register interface [eth2] MAC: 30:5a:3a:xx:xx:xx
Jan 30 22:52:42 kernel: PCI_PROBE: bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jan 30 22:52:43 kernel: dhd_attach(): thread:dhd_watchdog_thread:24fe started
Jan 30 22:52:43 kernel: Dongle Host Driver, version 1.363.45.58013 (r651509)
Jan 30 22:52:43 kernel: Compiled in drivers/net/wireless/bcmdhd on Jun 15 2017 at 14:50:24
Jan 30 22:52:43 kernel: Register interface [eth3] MAC: 30:5a:3a:xx:xx:xx
The 384_20287 GPLs are not ready yet. I don't need them right now, my focus is on 384.3 which will be based on 384_10007. The next GPL merge won't be until the next release.
Thanks.
Not to hijack my own thread.. but.. can anyone else confirm that their ASUS router/firmware is/was victim to the Chromecast flood that would kill the 2.4Ghz channel? Or that this is a confirmed / known issue with existing firmware(s)?
