RT-AC56U IPTV and IGMP proxy problem
Algimantas
Hello, I have RT-AC56U running 374.43_2 Merlin build.
My ISP provides internet on untagged VLAN 1 and IPTV on tagged VLAN 6.
In LAN->IPTV i have these options
With these options internet and IPTV works fine(LAN 3 && LAN4), however I want to watch IPTV on my PC (LAN1 and WIFI) aswell and that's why I enabled IGMP. However it doesn't seem to work.
/tmp/igmpproxy.conf
If i'm correct, in order to watch IPTV on PC, upstream of IGMP should be VLAN6 instead of eth0.
I couldn't find any option in the web gui to change the upsteam. Is there a way to change it from the CLI?
Another problem is with vlan6. In web gui I can see that LAN3 and LAN4 are assigned to VLAN6.
However if I type ifconfig or ifconfig vlan6 in CLI it says that it doesn't exist. I can only see VLAN1 and VLAN2 so I wouldn't be able to change the upstream to VLAN6 even if I knew how to.
Am I trying to do something impossible with this router or am I just doing it wrong?
Same problem. Techsupport says that configured vlans this ways is just bridges but made not by linux. It's some how other way :(
Now trying to make vlans and bridges just like in openwrt, but unsuccessful.
I see TX traffic, but theres no answer (RX) while internet working fine.
I receveid a reply from ASUS support and all they could say is that this feature is not supported on this router...
