My router isnt running 24/7, after especially a cold boot sometimes the NTFS USB drives (<= 2TB) showing filesystem corruption. It happens on USB2 or USB3 port each connected to a hub. I can fix that in AsusWrt webinterface.
I think I have to change partition and file system others than NTFS. So which combination is the most reliable using at the router? MBR or GPT, EXT xyz, which partion tool?
Thanky you and best regards.
