I just turned on and set up a VPN on my AC66. Using 380.63, but it also happened with 380.62. I have a couple of possible problems. First, the VPN does function, so I seem to be okay there. Here are the issues:
1. Even when the VPN (server 2) is turned on and in use, the Connection Status says "Disconnected" on the VPN Server - OpenVPN page.
2. On the same page, I tried to set up a Username and Password, but the router refused it, saying those were already in use elsewhere in the router (and indeed they are, so, okay). The problem is, there is now a row with the "bad" Username and no password in the grid. I can't edit or delete it (there is no minus sign on the row, just a hyphen). I was able to set up another Username and Password, and they work. I prefer to delete the "bad" one, but there does not seem to be a way to do it. Do I even need to worry about it? I have a similar situation in the VPN Server 1 (which is turned off).
