RT-AC66R w/380.69 and HP Color LaserJet M452dn
nitro001
Hello,
Have an odd scenario. I recently upgraded to 380.69 and from my Windows 8.1 machine, I cannot print any longer to my M452dn. A Test page just says failed to print, and printing from any app seems to send stuff to a void, where the print spool flushes it out quickly but the printer never sees it. It is using a HP TCP/IP Raw printer driver on a port.
What is really odd is my Wife's Mac running the latest OSX can print without an issue and I can print using my Pixel XL with the PrinterShare app.
Normally I would think this is just an app issue, but it had worked previously and the only change I really made was the upgrade to 380.69 on the router.
Has anyone run into this kind of thing before?
Thanks in advance.
Has the IP address of the printer changed? Check the Windows printer properties > port configuration still matches the DNS name or IP address.
Sorry been busy with the holidays. Nope, printer IP is the same, I can reach the Printers web page configuration and checked all the settings there as well, nothing new. All the configuration seems correct and my wife is still able to print from her configured settings.
