newbalance
Hi everyone,
I'm using the RT-AC66U router as my main router (connected to internet) and the RT-N66U in repeater mode. The main router uses WPA-personal for encryption with its clients. The repeater is connected with the main router on the 2.4 GHz band, also using WPA-personal for encryption with its clients. The repeater has its own SSID's (e.g. the main router uses SSID's 'ASUS' and 'ASUS_5G', the repeater uses 'ASUS-Repeater' and 'ASUS-repeater_5G'). When using this configuration, is the connection between the router and the repeater encrypted?
Thanks in advance.
Thanks in advance.
