Running an RT-AC66U (not B1) as AP with asuswrt-merin 380.70 which is the final release for this device.
On the UI, I can set any channel for 5 GHz just fine but after the WiFI subsystem restarts (or whatever it does to apply the changed setting), the channel will be back to "Auto".
I can monitor this on the command line; the related nvram setting gets overwritten.
Not so for the 2.4 GHz channel.
Is anybody facing the same, does this work for anybody? Does this effect relate to any settings?
